Revit 2019 no longer available?
9 REPLIES 9
Message 1 of 10
AndycMacp
621 Views, 9 Replies
We require Revit 2019 for certain projects but it does not seem to be available via the 'downloads' section? Apologies if I have missed something obvious but google or searching this forum doesn't seem to return anything.
Thanks in advance, I hope there is an easy answer like I am being dumb!
9 REPLIES 9
Message 2 of 10
in reply to: AndycMacp
Up to 5 versions back is what your subscription allows. So, 2019 should be available to you.
Message 3 of 10
AndycMacp
in reply to: barthbradley
@barthbradley just checked and it only goes as far back as 2020, is there another place to look?
Message 4 of 10
2023! Wow! I didn't realize we were there yet.  Still, 2023 - 5 = 2019.  Maybe Autodesk went back to the old way...3 versions back.
FWIW: https://knowledge.autodesk.com/customer-service/account-management/users-software/previous-versions/...
Message 5 of 10
Looks like you are eligible to download 3 previous versions.  So Revit 2020 is the last one you can get.  Maybe look into the Autodesk download folder (normally C:\Autodesk) see if you still have Revit 2019 installation files saved.
Message 6 of 10
in reply to: ToanDN
Looks like 2019 is available through AVA (per the Link I posted above).  I just checked.  Didn't press "Download" though. But it was available.
Message 7 of 10
Good call.  @AndycMacp  better be quick.
Message 8 of 10
l.debie
in reply to: ToanDN
@barthbradley@ToanDN
Unfortunately we're too late already...
Message 9 of 10
RDAOU
in reply to: l.debie
@l.debie
Do the following:
  • Sign Out
  • Clear the Browser Cash and Site History
  • GO to Autodesk AVA website and sign in
  • follow the steps in the below GIF (PS: this is from today 2022,04.06) so it is still available
Message 10 of 10
AndycMacp
I was also able to get 2019 by contacting Autodesk direct via the chat function
Forma Design Contest
