We require Revit 2019 for certain projects but it does not seem to be available via the 'downloads' section? Apologies if I have missed something obvious but google or searching this forum doesn't seem to return anything.
Thanks in advance, I hope there is an easy answer like I am being dumb!
Solved by RDAOU. Go to Solution.
Up to 5 versions back is what your subscription allows. So, 2019 should be available to you.
2023! Wow! I didn't realize we were there yet. Still, 2023 - 5 = 2019. Maybe Autodesk went back to the old way...3 versions back.
Looks like you are eligible to download 3 previous versions. So Revit 2020 is the last one you can get. Maybe look into the Autodesk download folder (normally C:\Autodesk) see if you still have Revit 2019 installation files saved.
Toan Nguyen
Looks like 2019 is available through AVA (per the Link I posted above). I just checked. Didn't press "Download" though. But it was available.
Good call. @AndycMacp better be quick.
Toan Nguyen
Do the following:
