While clicking on a linked model, one of the MEP guys received this error message. This happens when he is in any view. When I replicated the situation on my machine, the file worked perfectly. That led me to think that his machine needed a Temp folder cleanup (it did!!). Now after the cleanup the problem persists.
Why does this happen? And how can we fix it?
Solved by ennujozlagam. Go to Solution.
Does this only happen when he clicks on the linked file or when he starts to draw?
Also, have you tried to turn off hardware acceleration in the options of Revit?
When he clicks on the linked file. And this happens in all views.
Go to the "R" in the top left-hand corner and then click on options in the right-hand corner. Once there graphics tab and turn off the hardware acceleration on his machine
Hi @Anonymous. Didn't work. I have restarted his machine.
Update - he can work in the file, but things go crazy and the window shuts down when he clicks on the linked model.
Graphics Card was reinstalled this morning. No difference.
Current version
The DirectX diagnostics was run and it is working
Current version
Asked IT. Let's see what they say.
They say it's fine.
They say it's fine.
Thank you, @ennujozlagam. That machine is the same build as the machines that I work on. The file works well for me, not on this other machine.
@Sahay_R have you solve your issue? the worse scenario approach is to uninstall and reinstall the Revit program. It could be some files are corrupted. it's only my suggestion. thanks
Thank you @ennujozlagam. Yes a complete reinstall was done. I haven't heard anything afterwards. No news is good news, I guess!
