Received this error message - fix please.
16 REPLIES 16
Message 1 of 17
Sahay_R
566 Views, 16 Replies
While clicking on a linked model, one of the MEP guys received this error message. This happens when he is in any view.  When I replicated the situation on my machine, the file worked perfectly. That led me to think that his machine needed a Temp folder cleanup (it did!!). Now after the cleanup the problem persists.
Why does this happen? And how can we fix it?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
16 REPLIES 16
Message 2 of 17
in reply to: Sahay_R
Does this only happen when he clicks on the linked file or when he starts to draw?
Also, have you tried to turn off hardware acceleration in the options of Revit?
Message 3 of 17
Sahay_R
When he clicks on the linked file. And this happens in all views.
Rina Sahay
Message 4 of 17
Go to the "R" in the top left-hand corner and then click on options in the right-hand corner. Once there graphics tab and turn off the hardware acceleration on his machine
Message 5 of 17
Sahay_R
Hi @Anonymous. Didn't work. I have restarted his machine.
Rina Sahay
Message 6 of 17
Reinstall the videocard driver and if it doesn't help, reinstall DirectX.
Message 7 of 17
Sahay_R
in reply to: ToanDN
Update - he can work in the file, but things go crazy and the window shuts down when he clicks on the linked model.
Rina Sahay
Message 8 of 17
Sahay_R
in reply to: ToanDN
Graphics Card was reinstalled this morning. No difference.
Rina Sahay
Message 9 of 17
What about DirectX?
Message 10 of 17
Sahay_R
in reply to: ToanDN
Current version
The DirectX diagnostics was run and it is working
Rina Sahay
Message 11 of 17
It does not matter. Current version can be corrupted just like everything else. Re-install it.
Message 12 of 17
Sahay_R
in reply to: ToanDN
Asked IT. Let's see what they say.
Rina Sahay
Message 13 of 17
Sahay_R
They say it's fine.
Rina Sahay
Message 14 of 17
ennujozlagam
Hello, have you try to install latest updates from Microsoft and autodesk and see if helps. Thanks
Message 15 of 17
Sahay_R
in reply to: ennujozlagam
Thank you, @ennujozlagam. That machine is the same build as the machines that I work on. The file works well for me, not on this other machine.
Rina Sahay
Message 16 of 17
ennujozlagam
@Sahay_R have you solve your issue? the worse scenario approach is to uninstall and reinstall the Revit program. It could be some files are corrupted. it's only my suggestion. thanks
Message 17 of 17
Sahay_R
Thank you @ennujozlagam. Yes a complete reinstall was done. I haven't heard anything afterwards. No news is good news, I guess!
Rina Sahay
Forma Design Contest
