I have just installed revit but defaults to US METRIC . I need english metric. Have i installed the wrong version.
Units in Revit are defined per project, so you might use the right template, or just change them: => Manage => Project Units ("UN" Shortcut)
You can find the templates in C:\ProgramData\Autodesk\RAC 201*\Templates -> Select US Metric.
Or you can create a new project, change the units and save it as custom template.
Giuseppe
I think you mean UK Template versus US Metric Template, not units. If so, you need to run a re-installation of Revit and add the UK content.
