Phasing Graphic Overrides Not Working
6 REPLIES 6
PhilvK
492 Views, 6 Replies
The walls in the snip below are all 'new'. Why won't the new walls appear blue as I have set them using the setting below? Thank you.
6 REPLIES 6
in reply to: PhilvK
New is clearly black in your phase override setting.
PhilvK
in reply to: ToanDN
That's weird - the snip is showing blue as black. Here's another one:
in reply to: PhilvK
Are these the settings for SHOW NEW?
My guess is that New isn't overridden.
FWIW:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-D...
David_W_Koch
in reply to: PhilvK
Go to the Phase Filters tab, and look at the Show New line.  Does it say Overridden in the New column, or is it set to By Category?  The override will only be applied if it is set to Overridden.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
in reply to: PhilvK
Set show new filter to new = overridden.
Suggest to read this link to be familiar with Revit phasing.
https://blog.bimsmith.com/Working-with-Phases-in-Revit
PhilvK
in reply to: ToanDN
That's it!! Thank you all!
Forma Design Contest
Technology Administrators
