The walls in the snip below are all 'new'. Why won't the new walls appear blue as I have set them using the setting below? Thank you.
Solved by ToanDN. Go to Solution.
Solved by David_W_Koch. Go to Solution.
Solved by barthbradley. Go to Solution.
Are these the settings for SHOW NEW?
My guess is that New isn't overridden.
FWIW:
Set show new filter to new = overridden.
Suggest to read this link to be familiar with Revit phasing.
https://blog.bimsmith.com/Working-with-Phases-in-Revit
