Revit coordinate system
mbiAK7WZ
mbiAK7WZ
Hello there
i have the pleasure of started working on a project that is 10 months in process, and it is not in the right coordinate system, my question goes to how i can get it back into the right coordinates again. i have tried everything i know how to do atm. is there a easy way to my set my coordinates with the internal origin stays at 0.0.0?
my coodinates is
N/S 1159014960.0
E/W 37897867.9
Angle to true north 0 degrees
and they need to be
N/S 1158753946.3
E/W 378749107.5
Angle to true north 322 degrees
hope one of you have a smart way for me to change it
thanks
Internal Origin is always 0,0,0.
Specify Coordinates at Point:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/Revit-M...
Select Project Base Point and enter those values.
Scratch that.  Do use Specify Coordinates at Point and point to the Project base Point to enter the correct values.
I wouldn't enter those coordinate values into the project base point.
