Enlarged Details sharing the same viewport
4 ANTWORTEN 4
Nachricht 1 von 5
mbootsUJVFW
408 Aufrufe, 4 Antworten
Hi all,
Currently I'm trying to convert a lot of old AutoCAD details into Revit so I can use tags and other helpful features, however, I've run into a problem with trying to replicate a certain viewport; specifically, having a small, enlarged part of a view as a sort of tag in and of itself within the view, at a larger scale than the view itself. I've attached an image of what i mean since it's a bit hard to properly describe it, but is there any way within Revit to make a similar type of view callout?
Beschriftungen (3)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mbootsUJVFW
What about 2 views and 2 different scales placed next to each other?
Nachricht 3 von 5
mbootsUJVFW
als Antwort auf: barthbradley
That wouldn't allow me to have tags shared between the two views, however... also, since this is getting set up as a template for other projects, i was hoping it could be set up so you would only have to import a single view into a new project, rather than two different views and have to reposition them again every time you want to import it
Nachricht 4 von 5
There has been requests for a "Magnifier" feature/capability before - going all the way back to "Wish List" days.  Would be cool to have.   Maybe 2024.  Not holding my breath though.
Nachricht 5 von 5
It is very common practice.  Duplicate the drafting view, edit the content, change scale, and place it on the same sheet.
