Hi all.
Suddenly some part of a family is missing.
There is no crop view, no plan regions and I can see all the other.
Pic 1: Here is where its missing.
Pic 2: Its not hidden.
What is wrong?
Pic 3: Its visible in 3d view.
Maybe it's hidden in another Phase?
Check this list out:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Thanks for you reply, i checked it, but it is in the same phase as the others.
Have just found out, that i can make i visible with a plan region, but why only with this one only, I dont need plan regions for the others.
Plan Region??? Well, how do the Plan Region's View Range setting differ from the View's View Range settings?
...is this about a pony wall not cutting? If so, this is a Revit idiosyncracy.
http://therevitkid.blogspot.com/2012/01/revit-tip-short-wall-not-cutting.html
I'm just as confused as you.
The View range is set to 2300 - 1300 - 0mm and the plan region is set to 2300 - 1300 - -150mm, but why is plan region with minus offset, not necessary for the other, that is the same family.
Is the wall's Top Constraints set to "Unconnected"? Change it to a Level Name with an Offset distance.
It was det offset from host, it was 2 cm lower, then the other 🙄.
Thanks for your reply
I just noticed the -150mm for your bottom in your Plan Region settings. That tells me everything. The wall is below the Level. No wonder it doesn't show at 0mm.
