Part of family suddenly gone
9 REPLIES 9
Message 1 of 10
498 Views, 9 Replies
Hi all.
Suddenly some part of a family is missing.
There is no crop view, no plan regions and I can see all the other.
Pic 1: Here is where its missing.
Pic 2: Its not hidden.
What is wrong?
Pic 3: Its visible in 3d view.1.JPG2.JPG3.JPG
Hi all.
What is wrong?
9 REPLIES 9
Message 2 of 10
If i place a new one in same place, then i is visible in plan view and in 3d view there is 2 pieces
Message 3 of 10
Maybe it's hidden in another Phase?
Check this list out:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Message 4 of 10
in reply to: barthbradley
Thanks for you reply, i checked it, but it is in the same phase as the others.
Message 5 of 10
Have just found out, that i can make i visible with a plan region, but why only with this one only, I dont need plan regions for the others.
Message 6 of 10
Plan Region??? Well, how do the Plan Region's View Range setting differ from the View's View Range settings?
...is this about a pony wall not cutting? If so, this is a Revit idiosyncracy.
http://therevitkid.blogspot.com/2012/01/revit-tip-short-wall-not-cutting.html
Message 7 of 10
I'm just as confused as you.
The View range is set to 2300 - 1300 - 0mm and the plan region is set to 2300 - 1300 - -150mm, but why is plan region with minus offset, not necessary for the other, that is the same family.
Message 8 of 10
Is the wall's Top Constraints set to "Unconnected"? Change it to a Level Name with an Offset distance.
Message 9 of 10
It was det offset from host, it was 2 cm lower, then the other 🙄.
Thanks for your reply
Message 10 of 10
I just noticed the -150mm for your bottom in your Plan Region settings.  That tells me everything. The wall is below the Level.  No wonder it doesn't show at 0mm.
