None of the created elements are visible in Floor plan.
4 REPLIES 4
jgiraso
372 Views, 4 Replies
Hey Forum I need urgent help.
I am trying to add a section on a site plan and I keep getting the message "None of the created elements are visible in Floor Plan..." I made sure the Visibility/graphic tab everything in the annotation section is ticked but still can't see the section symbol. Sections are there but I can't see the symbol on the site plan.
4 REPLIES 4
jay_colcombe
in reply to: jgiraso
Check the Properties Palette and there may be a Parameter which references
Jay Colcombe
Autodesk Certified Instructor
jgiraso
Thank you. I just found that it was the discipline that was set to structure instead of Coordination or architecture.
jgiraso
in reply to: jay_colcombe
jay_colcombe
The Discipline Parameter will only turn on or off elements not annotations so setting it to Coordination you see all disciplines elements
Jay Colcombe
Forma Design Contest
