Hey Forum I need urgent help.
I am trying to add a section on a site plan and I keep getting the message "None of the created elements are visible in Floor Plan..." I made sure the Visibility/graphic tab everything in the annotation section is ticked but still can't see the section symbol. Sections are there but I can't see the symbol on the site plan.
Solved by jay_colcombe. Go to Solution.
Check the Properties Palette and there may be a Parameter which references
Thank you. I just found that it was the discipline that was set to structure instead of Coordination or architecture.
The Discipline Parameter will only turn on or off elements not annotations so setting it to Coordination you see all disciplines elements
