link dwg to family
5 REPLIES 5
2417 Views, 5 Replies
link dwg to family
Is it possible to link a DWG to revit family and control it in the revit family.
So if my family changes the dwg should also change with it, length and width.
Or if my dwg changes the family should change too.
It is a simple rectangle to a ceiling plate.
5 REPLIES 5
dzanta
you can import a CAD file into a revit family.  You cannot link a CAD file into a revit family.  If you import a CAD file into a family, you can only assign it a Yes/No parameter.  If you explode it, then it can be manipulated to "act" like a revit family.
Ultimately, it is just as easy to create the revit family from scratch and intelligent parameters.
Hope this helps
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
jostroopers
in reply to: dzanta
What I want to achieve is that I also want to link the  dwg to a Autodesk Inventor Part.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
dzanta
in reply to: jostroopers
sorry...I do not know inventor well enough to answer your question/request.
jostroopers
in reply to: dzanta
We now make a export of the family to autocad dwg.
That dwg i can link with my Inventor part.
So if the family change i have to make a new export and my Inventor part updates to.
Mvg Jos
maciejwypych
If you create the family in-place you can link a dwg
Forma Design Contest
Technology Administrators
