IFC Import: wrong orientation of opening/window
5 REPLIES 5
reitererMGQBZ
293 Views, 5 Replies
Hi, I have a simple IFC-file (see attachment) that comes from a different application.
The file contains a wall (with a window) that, when opened in Revit gives a wrong orientation of the window.
Here is the IFC-file opened in BIMvision, this visualization is correct and I expect the same orientation of the window when opened in Revit.
IFC-File opened in Revit (2025):
The window is rotated.
When linking the IFC-file, Revit correctly shows the window.
Why is there a difference when linking the IFC-File in Revit and when opening the IFC-File in Revit?
Is the IFC-File incorrect?
I observe the same (wrong?) behavior in Revit 2023, 2024 and 2025.
I need to open such IFC-Files correctly in Revit because I want to modify and extend the model.
Labels (1)
5 REPLIES 5
I have seen a couple of similar issues
Window rotated in Revit · Issue #549 · Autodesk/revit-ifc · GitHub
Does the following have an influence?
Export IFC changing Coordinate Base to Project base point.
Jay Colcombe
Autodesk Certified Instructor
What do you mean with "Export IFC changing Coordinate Base to Project base point."?
I get the IFC-File from a different application... I do not have impact on the coordinate base during export
Is there a (hidden) Revit-IFC-Import setting?
Corsten.Au
in reply to: reitererMGQBZ
Just for your information, I checked in Revit 2024 and 2025...
its linking correctly.
Revit 2025Revit 2025Revit 2024Revit 2024
Corsten
Building Designer
reitererMGQBZ
in reply to: Corsten.Au
Yes, i observed the same behavior (in Revit 2023, 2024, 2025).
But when opening the IFC-File, the orientation of the opening/window is wrong.
What is the problem there?
Has anybody an idea how the IFC-file needs to be modified so that it can be opened correctly in REVIT?
Forma Design Contest
Technology Administrators
