IFC Export 2024 moves the Window´s position after upgrading from 2022
jose.narea
jose.narea
We recently upgraded our model from Revit 22 to version 24. Initially, in Revit 22, our quality control checks indicated everything was fine, and we didn't encounter any issues with the IFC export. However, after the upgrade, we noticed a problem with exporting the model as IFC 2x3 or IFC4 – specifically, the window frames are shifted.
Has anyone else experienced a similar issue after upgrading from Revit 22 to 24? We would appreciate any insights or solutions you may have encountered.
Thank you in advance for your help!
jose.narea
We noticed that the problem occurred when the wall had an inclination of less than 0.3°.
