Can't recover journal file
amitQFEU3
amitQFEU3
hi,
my file crashed and wasn't able to save a backup file.
I try to recover the file via journal file, I followed the autodesk support tutorial, but the same massage appears, and than the original file is opening as last saved.
does anyone have any solution?
Simon_Weel
According to this article, "...  though note the chance to repair the data with journal files is very low."
Maybe there's a working local file, so check that out.
hmunsell
What Article told you could repair a model thru a Journal file?  don't get me wrong, i love journal Files, I use them regularly for Troubleshooting. but have never had success repairing a model with one.
The message in your screen capture usually implies the there was a pop-up message that was unaccounted for so it couldn't complete.  usually when I see those it's a "Reference not found" or a "Coordination Review" message.
  • Are you working with a Workshare file?
    • is there a Local you can recentralize?
  • Have you tried recentralizing the file with the error?
Howard Munsell
Create a support case to send the corrupted RVT file to Autodesk and the chance they will fix it is still greater than via a journal file.
