Message 1 of 10
Is Revit 2025 available to download? Can someone share a link to do so, or tell me where it is located?
yea its been out for 2 weeks
did you check your Autodesk Account?
you can also get it from here: https://forums.autodesk.com/t5/installation-licensing/2025-product-download-links/td-p/12663593
DarrenP
be careful; I truly think that this might be worse than 2024. I tested it for a day and it has way too many serious bugs. First time ever I'll wait few months with a new release.
Care to elaborate on what bugs specifically?
Due to the R2024 schema error, I decided to wait till January 2025 to install R2025. Did you use it in real projects, or just to play around?
I think that the only way to do tests is on a real project. There were various issues, but the major were multiple crashes and when it couldn't load links, that was it for me. I definitely don't want to waste again countless hours the same way as I did with 2024 schema errors, just because someone in Autodesk doesn't care about testing.
Ah, the results of what's essentially a monopoly...
If you already experienced crashes during normal operation, that would conclude any further testing before SP1 is out.
I was hoping so few new features would allow fewer issues with a new version.....
hi
please the link of source of Revit Full download
thankx
Hi Darren the link doesn't work I want to download revit 2025 and apply a key that I bought from another web site
