Revit 2025 Download
Revit 2025 Download
steve
Revit 2025 Download
steve
Is Revit 2025 available to download?    Can someone share a link to do so, or tell me where it is located?
DarrenP
yea its been out for 2 weeks
did you check your Autodesk Account?
you can also get it from here: https://forums.autodesk.com/t5/installation-licensing/2025-product-download-links/td-p/12663593
DarrenP
Karol_Piroska
be careful; I truly think that this might be worse than 2024. I tested it for a day and it has way too many serious bugs. First time ever I'll wait few months with a new release.
HVAC-Novice
Care to elaborate on what bugs specifically?
Due to the R2024 schema error, I decided to wait till January 2025 to install R2025. Did you use it in real projects, or just to play around?
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Karol_Piroska
I think that the only way to do tests is on a real project. There were various issues, but the major were multiple crashes and when it couldn't load links, that was it for me. I definitely don't want to waste again countless hours the same way as I did with 2024 schema errors, just because someone in Autodesk doesn't care about testing.
mhiserZFHXS
Ah, the results of what's essentially a monopoly...
HVAC-Novice
If you already experienced crashes during normal operation, that would conclude any further testing before SP1 is out.
I was hoping so few new features would allow fewer issues with a new version.....
