Insert Coordination Model 2024.2
10 REPLIES 10
Message 1 of 11
Imran.utnm
435 Views, 10 Replies
Hi all,i had a problem linking nwd file in revit using insert coordination model. In Revit 2023, i link shared coordinate nwd it work perfectly with the right coordinate and placement. I had issue with revit 2024.2 it place at wrong location. Is there any option for to collobrate with naviswork with revit. Thankyou
10 REPLIES 10
Message 2 of 11
in reply to: Imran.utnm
there all kinds of options depending on what setting you are using.  So far, you've highlighted an approach you are familiar with - that has worked in the past - but not working now, So, my guess is that something is "broke" - figuratively.  Seems like an easy fix.  Can you elaborate on how the problem manifests itself?
Message 3 of 11
Imran.utnm
okay,ill show u how i link nwd file with revit
we can easier collaborate with naviswork and revit with insert coordination link tool.
Instead of link the revit model in naviswork,this coordination link method help me a lot to move
any clashes
in the revit model.
 when insert the nwd,i've makesure all the model coordinate right. Then i cant add nwd file to shared coordinated.
 for revit 2023-2024.1 this tool work perfectly. When it comes to revit 2024.2
 and it effect all my past project when i use revit 2024.2. To be noted all model place at right place in naviswork. But not working well in the latest revit version 2024.2
Message 4 of 11
Imran.utnm
Message 5 of 11
Imran.utnm
 this is example before i update revit 2024.1 to 2024.2
Message 6 of 11
Imran.utnm
 This is what happend after the update
Message 7 of 11
tspeck
I am getting the same error with the coordination model coming in the incorrect location in Revit, were you able to resolve this?
Message 8 of 11
Imran.utnm
in reply to: tspeck
no solution yet
Message 9 of 11
tspeck
I got this message from Autodesk yesterday, stating there is bug with revit 2024 -Linked NWD coordination model not aligning to correct position in Revit 2024 (autodesk.com)
Message 10 of 11
Imran.utnm
in reply to: tspeck
still dont have any solution
Message 11 of 11
anze.kumar
Just a quick thought - could be nothing..
did you try and test the "Reload From.." option. Somethimes with .dwg files, this helps to put an imported file into the correxct position.
Maybe also try and trst "Positioning" _> Origin to Origin
Forma Design Contest
Technology Administrators
