IFC Export Problem- Wall Cuts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am facing an issue rated to Revit IFC Exporter
When I export IFC file from Revit 2021 to Orca (IFC Mengenübernehmen) , SimpleBIM software or even solibri , I found that there is missing data rated to the doors cuts in the walls. In other word It shows that there are doors in the walls in 3D but when I hide the Doors elements from the view, It shows the walls without any cuts in it for the doors.
I am using Revit 2021 with last update for IFC exporter (21.2.1.0) , Also I am using the standard IFC settings ( IFC 2*3 Coordination View 2.0 Setup). While my colleague in the office tried to export it from old Version like IFc Exporter (21.1.0.0), he found that it works good.
As you are seeing the screenshot, I would like to know why it happens , thanks for your help
