Is there any way to split the workspace in revit to small sheets with symbols on sheets that indicate that there is more sheets that display the rest of the information?
danezeq
danezeq
This methood is used by project that spread over lots of area, and usually dome with autocad. i've never saw it implemented on Revit.
I think it's called "divide to keymap"
i can do it manually with symbol and text inside but that a silly job and taked lot's of time.
(btw please ignore the aerial photo)
cbcarch
Use Matchlines.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Alfredo_Medina
...and View References.
syman2000
How I achieve this is to use duplicated by dependent view. In this dependent view, you would crop it to smaller area to fit into your sheet. The parent view will have all your plan and the dependent is just snapshot of smaller drawing area. Afterward you use matchline as @cbcarch mentioned above to indicate the split between the plan. As well use view reference to reference to different plan as @Alfredo_Medina mentioned above.
