IFC Export Problem- Wall Cuts
Message 1 of 15
I am facing an issue rated to  Revit IFC Exporter
When I export IFC file from Revit 2021 to Orca (IFC Mengenübernehmen) , SimpleBIM software  or  even solibri , I found that there is missing data rated to the doors cuts in the walls. In other word It shows that there are doors in the walls in 3D but when I hide the Doors elements from the view, It shows the walls without any cuts in it for the doors.
 I am using Revit 2021 with last update for IFC exporter (21.2.1.0) ,  Also I am using  the standard IFC settings ( IFC 2*3 Coordination View 2.0 Setup).  While my colleague in the office  tried to export it from old Version like IFc Exporter (21.1.0.0),  he found that it works good.
As you are seeing the screenshot, I would like to know why it happens , thanks for your help
Replies (14)
Message 2 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check on Revit 2022
https://www.autodesk.com/products/revit/free-trial
If it is not correct , please post example Revit file.
Rafal Gaweda
Message 3 of 15
Foremost, thanks a lot for your reply. In our office we use Revit 2021, until now we did not buy  Revit 2022, I read in Github that they are developed a new IFC exporter 22.1.0 which I can not install it on  Revit 2021. I hope that Autodesk  developed a new IFC exporter for Revit 2021. because Trial Version will  be valid for only 30 days which  not useful for our office. Thanks again for your efforts and your help
Message 4 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
So post example Revit file.
Rafal Gaweda
Message 5 of 15
Hi @Rafal.Gaweda ,
here is the Revit file
Message 6 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
In case of Revit 2021 -> unistall IFC 2021.
Revit 2022 exports IFC (with \ without IFC 2022) correctly.
Rafal Gaweda
Message 7 of 15
@Rafal.Gaweda
 what do you mean ( With / without IFc 2022) ? I did not get your point
  Also i would like to ask , is it possible to uninstall IFC exporter 21.1.0 and install IFC 22.1.0 for revit 2021
Message 8 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I meant https://github.com/Autodesk/revit-ifc/releases
22.1.0 is for Revit 2022
Rafal Gaweda
Message 9 of 15
@Rafal.Gaweda  I saw it before, but I do not know if is it possible to uninstall IFC exporter 21.2.1 and install IFc exporter 22.1.0  for Revit 2021 ? , it is the important question because It mentioned in github website that It is for Revit 2022. Thanks
Message 10 of 15
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
As I wrote in post 8 and as it is written on github, release 22.1.0 is "for Revit 2022 out-of-the-box".
Rafal Gaweda
Message 11 of 15
Ok thanks a lot for your reply and your help
Message 12 of 15
marcin.szulc76AAZ
The same problem with IFC export from rvt2021.
So what should we install instead of IFC 2021 when we don't have rvt2022 in office?
Message 13 of 15
@marcin.szulc76AAZ I found  a script for IFC exporter 21.3.0 on GitHub, but there is not  an installation program  in website, only coding script.
Message 14 of 15
asWAPL9
page not found. have the same problem in revit 2021
Message 15 of 15
marcin.szulc76AAZ
Apparently we don't have this problem any more, but unfortunately I don' know what was improved...
Probably some updates helped.
