Before I go too far down the rabbit hole i'm would like to check if the following is possible.
Not everyone in the business currently understand the ISO19650 Status codes so I want to put a small description of what the status code means at the bottom of each titleblock Sheet.
The drawing can only be a number of Status's eg. S0, S3, A4, A5 etc. I want to create a lookup formula that looks for the two digit status in one shared Instance parameter and then displays the description of that status in a different parameter e.g.:
ISO19650_Status = S0
ISO19650_Status_Definition = IF (ISO19650_Status = S0 THEN "Work In Progress), IF (ISO19650_Status = S3 THEN "Suitable for Review & Comment") etc... I know the syntax is incorrect at this point.
Any help would be most appreciated.
Cheers
Solved by ToanDN. Go to Solution.
Ok thanks for getting back to me that has saved me some considerable time. I may be able to work a solution using your tip.
Cheers
Mark
