I've inserted a structural framing that is not visible in floor plan, but I can see it in a section or 3d view.
I already tried to change the discipline, created a filter, change the view range, the template, removed all the links. But nothing works.
floor plan
Section
Create a new floor plan without any template or filter. If it is not visible check first for view range and phasing.
Otherwise, you might check these 33 possibilities.
Check the Visibility Settings in the Family. Is it Visible in Plan and Elevations?
This is my file, I'm having the same issue aswell
