I can't see a structure frame in floor plan
13 REPLIES 13
Message 1 of 14
douglas.taguchi
2651 Views, 13 Replies
I've inserted a structural framing that is not visible in floor plan, but I can see it in a section or 3d view.
I already tried to change the discipline, created a filter, change the view range, the template, removed all the links. But nothing works.
floor planfloor planSectionSection
13 REPLIES 13
Message 2 of 14
Avaris.
in reply to: douglas.taguchi
Create a new floor plan without any template or filter. If it is not visible check first for view range and phasing.
Otherwise, you might check these 33 possibilities.
Message 3 of 14
douglas.taguchi
in reply to: Avaris.
Nothing works.
Message 4 of 14
Check the Visibility Settings in the Family.  Is it Visible in Plan and Elevations?
Message 5 of 14
Message 6 of 14
Is this a Link?  In a Workset too?
Message 7 of 14
No. It's a structure frame family. And I'm just using one workset.
Message 8 of 14
Just post your file here. We'll figure it out quickly.
Message 9 of 14
in reply to: barthbradley
This is my file, I'm having the same issue aswell
Message 10 of 14
in this case, what can I do ?
Message 11 of 14
cinthiadaianasing
Invalid Page URL
Message 12 of 14
_Vijay
Did you check with detail level in visibility settings?
Message 13 of 14
_Vijay
i can see them
Message 14 of 14
_Vijay
in reply to: cinthiadaianasing
