hi i have folded roof but i cannot attach all of my wall at the bottom of the roof.
any one can help ? thx a lot
here i attach my file
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
The wall is not within the footprint of the roof...Either move the wall under the roof or slightly adjust the roof.
I have tried it works, but there is something wrong again .what happened ?
@Anonymous
The attach detach was the wall being outside the footprint of the roof...This is something ELSE. You have a gap in between the roofs through which the wall is bleeding/not attaching. Zoom out, align and close the gap between the 2 roofs and that bleeding piece will be gone
sorry i have checked there is no gap, i try to align it but it cant
in the left side of the roof there is no problem just in the right side the wall cant attach perfectly
@Anonymous
This is your model in the GIF above...and there is a gap! You need to tidy up your roof
Anyhow...I hope that we are not solving all the problems in that model in one post ![]()
It is fine! Just zoom in to the roof and have a closer look
