In the image below I want to insert wood blocking at the top of a wall.
But I have been unable to remove the plywood that is there.
How can I do this?
Thank you for your help.
How can I do this?
Solved by dzanta. Go to Solution.
In that same Edit Assembly window, look in the lower right corner. You will see sweeps and reveals command. You can use the sweep command and place it at the top of the wall. Use the offset value within the profile to adjust how deep it cuts into the wall.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Hi Bruce...
Find the answeres from below link.
This is to add sweep in wall: https: //knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Model/files/GUID-93F44C38-8158-4F7D-94E3-C076E1367786-htm.html
This is about deleting layer in wall : https://forums.autodesk.com/t5/revit-architecture/delete-layer-in-edit-wall-type/td-p/5402441
I think these links may help you...
Hi Bruce...
What do Sweeps and Reveals do?
Please see the following screencast on a basic tutorial on sweeps and reveals within walls.
