Connecting Railings?
5 REPLIES 5
301 Views, 5 Replies
Okay, not the best question to try and explain, and I can't take screenshots, so I will do my best for explaining,
When you make stairs you get a railing with it, if not you can make your own,
so I have stairs but I also have platforms, or a catwalk at the tops of the stairs some at the bottom with railings as well,
where they meet they don't connect the ones on the stairs are higher then the ones on the platform, changing the elevation doesn't work. I know there can be Transitions or Extension Style, if that was what I would need to do, I don't see the options there, unsless I'm looking in the wrong spot.
Can anyone tell me what I can change,
Thank you.
5 REPLIES 5
dzanta
you mean like this?
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
in reply to: dzanta
Yes like that,
I found the others ways I had mentioned I couldn't find before, I can edit it but making any of the changes doesn't change anything.
dzanta
look at the properties of the railing on the stair versus the railing on the platform...they should be identical.
in reply to: dzanta
They are identical.
dzanta
can you upload your revit model so I can see the data...I think there is something minor we are missing.
