How to modify a wall?
4 REPLIES 4
363 Views, 4 Replies
In the image below I want to insert wood blocking at the top of a wall.
But I have been unable to remove the plywood that is there.
How can I do this?
Thank you for your help.
How can I do this?
4 REPLIES 4
dzanta
dzanta
In that same Edit Assembly window, look in the lower right corner.  You will see sweeps and reveals command.  You can use the sweep command and place it at the top of the wall.  Use the offset value within the profile to adjust how deep it cuts into the wall.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
PrathapSekar
PrathapSekar
Hi Bruce...
    Find the answeres from below link.
   This is to add sweep in wall: https: //knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Model/files/GUID-93F44C38-8158-4F7D-94E3-C076E1367786-htm.html
   This is about deleting layer in wall : https://forums.autodesk.com/t5/revit-architecture/delete-layer-in-edit-wall-type/td-p/5402441
I think these links may help you...
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Hi Bruce...
in reply to: dzanta
What do Sweeps and Reveals do?
dzanta
dzanta
Please see the following screencast on a basic tutorial on sweeps and reveals within walls.
