How to Model A Curved Ramp of Irregular Shape ?
7 REPLIES 7
Message 1 of 8
hliS658H
2340 Views, 7 Replies
How to model this curved ramp with different widths?
7 REPLIES 7
Message 2 of 8
Alfredo_Medina
in reply to: hliS658H
Do it as a floor, then elevate the end edge to the desired elevation.
Message 3 of 8
hliS658H
in reply to: Alfredo_Medina
Do you mean use sub elements? How can I control the slope along the center line?
Message 4 of 8
cbt990
Architecture > Ramp > select the two long edges as boundaries and the two short edges as risers.
Revit is amazing
Message 5 of 8
there are some different methods to do this...
  1. one , is just to use the Ramp , but the result is not quite satisfactory , in my opinion
  2. another one is to use Floors with Modify Sub Elements , as Alfredo suggests - I. also prefer this method
  3. and finally you can use Mass and Roof by Face with a similar result as method 2 but with more work..
I've attached a rough screencast that shows the method 3 ( compared with other 2 )
https://www.youtube.com/watch?v=jvdE4GejNfo
Constantin Stroescu
Message 6 of 8
hliS658H
in reply to: cbt990
I got the error messages as below shown, not sure if it is because the two long edges are not continuous lines, but consist of two segments (curve + straight line) respectively, not sure how to make a continuous line in Revit such as polyline in AutoCad.
Message 7 of 8
Model it as one ramp may show some undesired warp.  I would do it as two ramps by sketch.
Message 8 of 8
hliS658H
in reply to: ToanDN
I currently use sub elements method but not prefer, since the model is easily get messed up by people who don't know this method.
Having some problems using ramp method - I use the elevations to control the ramp, the slope can vary as long as it is within the permitted scope
Forma Design Contest
Technology Administrators
