Fill pattern library
1 REPLY 1
1661 Views, 1 Reply
I am quite new to Revit Architecture and I would like to use fill patterns that are not already in Revit. I know that I can create one on my own, but maybe you know some good online library with .pat files? I already checked revitcity, but it seems that most of pat files there are just elevation patterns, and I would like to get more patterns for cut walls like brick, concrete or insulation hatches.
1 REPLY 1
hugha
Revit employs two types of fills, MODEL and DRAFTING.  MODEL for materials and filled regions and DRAFTING for cross-sections.
You can copy, rename, scale, rotate and change a loaded fill's type within Revit with the free HatchKit Add-In for Revit.
Forma Design Contest
Technology Administrators
