Revit 3D view is incomplete at some angles
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
421 Aufrufe, 1 Antwort
Hello All,
I`ve been working on a project for a couple months for a research project. Nearly all the family objects were customized to a high level of detail using the Specialty Objects family type.
Recently my 3D view has stopped working correctly. At some particular angles the project is blank. All of the elevation views work correctly and I am only noticing the error in the 3D view. Any ideas why and how I can fix this?
For example, the first view has cut off the top of the project and the second view is missing the entire left side of the project.
The only 3D view which I can see the entire project is from behind at one particular angle.
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: Anonymous
Deselect the "Crop View" setting and see what happens.
Louis
Please mention Revit version, especially when uploading Revit files.
