Fill pattern library
I am quite new to Revit Architecture and I would like to use fill patterns that are not already in Revit. I know that I can create one on my own, but maybe you know some good online library with .pat files? I already checked revitcity, but it seems that most of pat files there are just elevation patterns, and I would like to get more patterns for cut walls like brick, concrete or insulation hatches.
hugha
Revit employs two types of fills, MODEL and DRAFTING.  MODEL for materials and filled regions and DRAFTING for cross-sections.
You can copy, rename, scale, rotate and change a loaded fill's type within Revit with the free HatchKit Add-In for Revit.
