Please help
I use revit 2017.I am using wall sweeps to create concrete coping on top of a boundary wall.I am not sure is using wall sweeps is the best option for this purpose,please advise.However my problem is,when i place the wall sweeps in 3d and are at the same level directly above two walls that are intersecting and trimmed,the wall sweeps are not getting trimmed.Below is an image to showing the problem i have mentioned here.
Your help will be greatly appreciated
Gelöst! Gehe zur Lösung
Gelöst von PijPiwo. Gehe zur Lösung
Make sure the grips are on top of each other. Drag them if they don’t. If it still doesn’t work, please upload your file.
