I built a Family that shows in all views exepct my camera views. This is causing issues becuase I am unable to render it becuase it does not show up in any view. Also my storefront wall windows are not cutting through the walls, the walls are shown as blank in my camera views. Hoping to get some help!
Thanks for trust and share your problem here in forum , first i want to check if you took a camera view from plan or 3D because it is a common problem i noticed with somr revit users , you need to take the camera from plan view and check the name of view , and i for the wall sure your camera angle or edit color of wall grom graphics.
i hope it helps you
