Families: Save Out Multiple RFA's from Project RVT
clara_csdrafting
clara_csdrafting
Is there a way to save out families loaded into a project, ones I select, in one step -- instead of doing so one by one?
I have a habit of creating a family, loading it into a project, then downstream if I further edit the family I don't always ensure the saved out RFA matches the version used in my project.  I'd like a less tedious way to ensure an RFA library is up to date.
Thank you,
- Clara P. Sandoval
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
L.Maas
Use the "Save As", "Library", "Family". It will save all the families in your project to a folder of your choice.
Louis
Please mention Revit version, especially when uploading Revit files.
clara_csdrafting
Interesting.  This seems to not let you pre-select specific families or all families of a category but at I can work with this -- blow away the ones I don't want after.  And I'm reminded: no periods in file naming (get replaced w/ "-") and smart naming is key!
