Elevation Tool is grayed out
7 REPLIES 7
Message 1 of 8
Stephm419
16924 Views, 7 Replies
I am doing blow out plans and interior elevations. When I make the call out for the plan the elevation butti0on is grayed out?
This is really frustrating!
Please help
7 REPLIES 7
Message 2 of 8
in reply to: Stephm419
Which version of Revit are you using?
Message 3 of 8
Stephm419
2012
Message 4 of 8
Stephm419
Do you have any ideas?
Message 5 of 8
fernanda.firman
Thank you for visiting our forum!
Can you please share a sceen shot?
Do you mean the elevation symbol?
If you are talking about the elevation symbol, I would suggest checking if the "hide in views smaller than" is set to the correct scale of your view. Please see the image attached.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Message 6 of 8
Stephm419
in reply to: fernanda.firman
I figured out what was happening. What I started the Call out tool the type was set to "detail View" not "Floor Plan.
So now I am stuck with another situation, how do I change the callout detail views to callout floor plan views?
Message 7 of 8
fernanda.firman
Unfortunately, once you've created a Detail view you CAN'T change it.
Autodesk, Inc.
Revit Clinic
Message 8 of 8
rsovaJQ4N7
I just experienced this same issue. It's ridiculous that you can't add an elevation reference within a detail view. This issue is still present in R23...
Forma Design Contest
