Error: can't create sweep blend command
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
cengizkirar085
271 Aufrufe, 3 Antworten
when i try two different profile on on zigzag line by sweep blend command its not work shows me some error.sweep blend.PNG
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: cengizkirar085
My guess is that the Profiles are too big.  Make them smaller.
Nachricht 3 von 4
handjonathan
Hi @cengizkirar085
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 4 von 4
cengizkirar085
als Antwort auf: handjonathan
Yes i got answer
