I am doing blow out plans and interior elevations. When I make the call out for the plan the elevation butti0on is grayed out?
This is really frustrating!
Please help
Solved by Stephm419. Go to Solution.
Thank you for visiting our forum!
Can you please share a sceen shot?
Do you mean the elevation symbol?
If you are talking about the elevation symbol, I would suggest checking if the "hide in views smaller than" is set to the correct scale of your view. Please see the image attached.
I figured out what was happening. What I started the Call out tool the type was set to "detail View" not "Floor Plan.
So now I am stuck with another situation, how do I change the callout detail views to callout floor plan views?
Unfortunately, once you've created a Detail view you CAN'T change it.
I just experienced this same issue. It's ridiculous that you can't add an elevation reference within a detail view. This issue is still present in R23...
