Elements appear transparent
18 REPLIES 18
Message 1 of 19
cbt990
645 Views, 18 Replies
I am trying to adjust the display settings for these mailbox elements, so that the curtain grids behind them do not show through. I have tried overrides by element, no luck.
Revit is amazing
18 REPLIES 18
Message 2 of 19
in reply to: cbt990
Are you in Wireframe View?
Doesn't look like any of the Mailbox geometry in visible in elevation - or maybe the mailbox material is transparent.
Message 3 of 19
in reply to: cbt990
Check VG for the category transparency.  And share the mailbox family for less guessing.
Message 4 of 19
in reply to: cbt990
Mailbox courtesy of BIMObject:
Mailbox is "see-through" in Project:
Edit Mailbox Family, check these boxes in the Visibility Settings for the large extrusion representing the box and then Reload Family into the Project:
Result back in the Project:
Message 5 of 19
cbt990
in reply to: barthbradley
This worked for part of the mailbox but not the entire object.
Revit is amazing
Message 6 of 19
in reply to: cbt990
Post the family and I'll fix 'er up for you.
Message 7 of 19
cbt990
https://we.tl/t-qfSmAfACdh
Revit is amazing
Message 8 of 19
in reply to: cbt990
Still, the same workflow. Select the Geometry in the Family, press Visibility Settings and check boxes.
Message 9 of 19
in reply to: cbt990
Aside from fixing the transparency, shouldn't you place curtain grids around the mailbox area, change the curtain panels behind the mailboxes to Empty System Panels to create the opening for the mailboxes?  Or are they surface mounted?
Message 10 of 19
cbt990
Trying the same workflow:
Revit is amazing
Message 11 of 19
in reply to: cbt990
The Mailbox was probably  meant to use Masking Regions in Elevation, and the creator forgot to add them.  Maybe they got lost in the mail.  😉
Message 12 of 19
in reply to: cbt990
See my reply above regarding boxing out a space in the curtain wall for the mailboxes.  As shown, your curtain panels may be on the same plane as the face of the mailboxes so they still show.  Share a 3D view for confirmation.
Message 13 of 19
in reply to: cbt990
What's the f'ing deal here, @cbt990???  Solution goes to @ToanDN???  For what???
Are you guys sleeping together or something?
See ya, Wouldn't want to be ya.
Message 14 of 19
cbt990
in reply to: cbt990
Everyone has received credit
Revit is amazing
Message 15 of 19
cbt990
Sorry, I have given your solution credit!
Revit is amazing
Message 16 of 19
cbt990
Follow up issue with another family. Tried the troubleshooting steps that worked here, got me part of the way there.
here's the family .. https://we.tl/t-x4LdN1eEIy
Revit is amazing
Message 17 of 19
in reply to: cbt990
You are looking at the back of the mailbox.  Press Space a couple of times to flip it.
Message 18 of 19
cbt990
in reply to: ToanDN
Ok, that was half of the issue:
Revit is amazing
Message 19 of 19
in reply to: cbt990
Edit nested families and check box.
Forma Design Contest
Technology Administrators
