Does Revit let you put vertical curves on rails?
David125
David125
...as in the image below?
Sure. Edit Top Rail.
Help | Modify a Continuous Rail | Autodesk
handjonathan
Hi @David125
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
David125
Yes, I just accepted it as solution.
David125
Which version of Revit is this?
Any version with Top Rails. I can't remember when they were introduced.  It has been years though.  If your Railing has a Top Rail, you need to use the TAB key to select it (e.g. TAB -Select).
It can be had automatically by set the top rail type with a floor extension, and joint condition with a radiused fillet.
