Hi @David125
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Technical Marketing Manager | Construction
Any version with Top Rails. I can't remember when they were introduced. It has been years though. If your Railing has a Top Rail, you need to use the TAB key to select it (e.g. TAB -Select).
It can be had automatically by set the top rail type with a floor extension, and joint condition with a radiused fillet.
