Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Does Revit let you put vertical curves on rails?
David125
David125
...as in the image below?
Sure. Edit Top Rail.
Help | Modify a Continuous Rail | Autodesk
handjonathan
Hi @David125
Thanks a lot for posting your question to the forums!   Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
David125
Yes, I just accepted it as solution.
David125
Which version of Revit is this?
Any version with Top Rails. I can't remember when they were introduced.  It has been years though.  If your Railing has a Top Rail, you need to use the TAB key to select it (e.g. TAB -Select).
It can be had automatically by set the top rail type with a floor extension, and joint condition with a radiused fillet.
