Crop snaps in view
Crop snaps in view
s222290629
Message 1 of 49
Crop snaps in view
s222290629
I need to know how can I have the blue points snap on inner rectangle?
Kind regards,
Arman
Replies (48)
Message 21 of 49
It crops differently than the original. Is it not what you want?
Message 22 of 49
s222290629
I changed scope box to AMCC again and this happened!
Message 23 of 49
No, you are resizing the view crop. You need to resize the scope box itself otherwise nothing will change when you reassign the scope box back to the view.
Go back to the instruction I gave on how to reveal the scope box and resize it.
Message 24 of 49
s222290629
I'm here now, scope box in none now
Message 25 of 49
s222290629
How can I do that, I mean resize the scope box , what should I do?
Message 26 of 49
Uncheck Crop view, turn on Scope box from VGO anno tab.
Message 27 of 49
s222290629
I did exactly what you said, then?
Message 28 of 49
The view you show in the picture is still cropped. Uncheck Crop View box and uncheck Show crop region box, please.
Message 29 of 49
s222290629
Sorry, is that ok?
Message 30 of 49
Uncheck Crop region visible box as well.
Message 31 of 49
s222290629
This happened
Message 32 of 49
That's okay. Now type VG, switch to Annotation tab, turn on Scope Box category.
Message 33 of 49
s222290629
ok, I did, then?
Message 34 of 49
Show the screen after you did.
Message 35 of 49
s222290629
Message 36 of 49
One of the green rectangles is the scope box that you need to resize.
Message 37 of 49
s222290629
this is the one, but still I don't have the grips on it to resize!
Message 38 of 49
Do not assign the view with the scope box.  You have not resized the scope box then you are just back to the square one.
Just share the project then I will show you.
Message 39 of 49
s222290629
Sorry, but this is a company project, is that ok?
Message 40 of 49
Is what okay?  If you can't share then you can't share.
Now you need to go back to the view where you see a bunch of green boxes, find the one with the name AMCC, select and resize it.  After that, set your view to use the scope box AMCC again then you will see the difference.
Worst case scenario if you still can't do it, forget scope box, set the view to None and stretch the view crop.
