Create specific walls in Revit.
5 REPLIES 5
873 Views, 5 Replies
Hello! Can someone can help out with this isuee what you see in picture. How to create walls whats not by basic parameters. In picture I have dwg picture from autocad and i create things on top of it.
@Anonymous,
zsolt.varga has embedded pictures for clarity.
5 REPLIES 5
ennujozlagam
hello, you can try model in-place > walls > extrusion. thanks
in reply to: ennujozlagam
i need to connect both walls i dont find such a option extrude
Avaris.
You can make a wall extrusion in place and afterwards modify>join.
in reply to: Avaris.
I don't really see what your issue is? I was able to recreate what you were looking for just using basic wall types and using the disallow join command and then rejoining elements using the join tool.
Zsolt.Varga
Hi @Anonymous
I agree with @ennujozlagam - the approach with creating an in-place wall drawing extrusion shape on the floor plan and extruding the wall upwards seems to be the right approach to me.
I´ve just made a video for you to show how to model the geometry with 2 normal walls and an in-place mass wall and how to have the geometry as one single peace of an in-place mass extrusion wall.
I hope this helps, please, remember to mark this as an "Accepted solution" if it does - this way you can help other users with similar questions as well.
Zsolt Varga
Technical Support Specialist
Revit Ideas | Screencast | Revit Help | AKN
Forma Design Contest
