Create specific walls in Revit.
Hello! Can someone can help out with this isuee what you see in picture. How to create walls whats not by basic parameters. In picture I have dwg picture from autocad and i create things on top of it.
@Anonymous,
zsolt.varga has embedded pictures for clarity.
ennujozlagam
hello, you can try model in-place > walls > extrusion. thanks
i need to connect both walls i dont find such a option extrude
Avaris.
You can make a wall extrusion in place and afterwards modify>join.
I don't really see what your issue is? I was able to recreate what you were looking for just using basic wall types and using the disallow join command and then rejoining elements using the join tool.
Zsolt.Varga
Autodesk Support
Autodesk Support
Hi @Anonymous
I agree with @ennujozlagam - the approach with creating an in-place wall drawing extrusion shape on the floor plan and extruding the wall upwards seems to be the right approach to me.
I´ve just made a video for you to show how to model the geometry with 2 normal walls and an in-place mass wall and how to have the geometry as one single peace of an in-place mass extrusion wall.
I hope this helps, please, remember to mark this as an "Accepted solution" if it does - this way you can help other users with similar questions as well.
Zsolt Varga
Technical Support Specialist
Autodesk, Inc.
Revit Ideas | Screencast | Revit Help | AKN
