Control Hatch Pattern Line Weights
Message 1 of 81
I found this being posted by number of people and a lot of answers marked as solutions. But they don't seem to work.
Hatch patterns seem to be understood as taking a default pen width 1. So While playing around for changing these hatch weights, I changed all pen 1 widths to 0.5mm, for all scales, in Manage > Settings > Additional Settings > Line Weights > Model Line Weights - Perspective Line Weights > Annotation Line Weights.
Nothing seems to change hatch pattern or cut surface pattern line weights. Could any sage help?
Accepted solutions (4)
Replies (80)
Message 41 of 81
RobDraw
@jsanders wrote:
Autodesk has decided to not make this feature possible and so we will never be able to control the thickness of our walls patterns.
That's right. The programmers decided to stick it to the users.
@jsanders wrote:
you are making the discussion sterile.
I don't see you contributing a solution, either.
Rob
Message 42 of 81
chaldeman
Since the lines of a fill pattern used as a cut pattern for walls in Revit appear to default to Model Line Weight 1, and Revit does not offer (as of Revit 2020) the ability to change this default, the only way I can see to control the line weight of walls' cut patterns in Revit is to change the width of Model Line Weight 1 (for each view scale) to the desired width of your wall cut pattern. Then, change all other Object Styles in Revit so that none of them use Model Line Weight 1.
The upside to this workaround is that you could then control the weight of the lines in your wall cut patterns.
The downside to this is that the weight of the lines in all wall cut patterns in all walls in Revit would have to use that same line weight (Line Weight 1).
Message 43 of 81
David125
This doesn't really solve anything, does it? Why is it marked as a solution?
Message 44 of 81
See post #20.
Message 45 of 81
RobDraw
The OP was the one that marked it as a solution. You would have to ask that person. Sometimes people mark posts as solutions because it helps them understand or because it was helpful in some way. There are no rules as to what can be marked as a solution even if there isn't one.
Rob
Message 46 of 81
Cucu_Setiawan
Sorry, maybe I'm late.
I have a solution for hatch line thickness, You can download the Dynamo definition here
Message 47 of 81
nathaniel.mcmahon
Lol using  dynamo to define hatch line weight. That's how I like to bill my client.
Simply being able to define which "system" lightweight is used per material or hatch pattern is what's missing.
Message 48 of 81
RobDraw
This forum is for solutions. Not all of us have to justify how we get the job done, plus you don't have to bill your client for it if you don't want to when you use it.
Feature requests belong in the IDEAS forum.
LOLing at someone attempting to help is out of line.
Rob
Message 49 of 81
nathaniel.mcmahon
Sorry just trying to alleviate the drudgery of being an architect, wasn't meant to be personal.
Message 50 of 81
esr712
The answer to this issue is in object styles (not visibility / graphics overrides). Try changing the line-weight of your category up (or down) to see if that works for you.
@Anonymous  Let me know if this helps you.
Message 51 of 81
lmpka
From what I understand, the hatch pattern is controlled by the Object Styles line weight.  Line weight overrides don't affect the line weight of the hatch pattern.
So you set the line weight in object styles that you want to use for the hatch pattern, then use the visibility graphics overrides to change the line weight used for the object.  So, if you wanted your floors to have thick lines for the outlines, and thin lines for your hatch pattern, in the Object Styles override, you'd set the line weight to 1 for the floors, and then in the visibility graphics overrides, you'd set the line weight to 4 (for example).
If it's a linked background model, then you're out of luck unless you want to go into it and adjust it every time you get an update.
Same thing as stated above, just a little more verbose.
Message 52 of 81
David125
Is it possible to control the line weight of a pattern in a ceiling? It would be nice to show new/demo ceiling line wight as bold.
Message 53 of 81
michael.hansonF4L5R
It seems like this thread has digressed...
I'm not here to offer a solution, but I'm seeking a similar work around.
So, by way of example, I'm contributing a real world example of why it would be useful to be able to affect the surface pattern or cut pattern of an element. (Not via a Fill Hatch Region)
Architectural problem:
I need to convey the extents of the demolition of a roofing membrane in plan and the insulation below. Membranes in general do not have a surface pattern. So, the phasing graphic override has no affect. I added a surface pattern using a custom pattern I created with dashed lines to denote demolition. However, the line weight is automatically set to 1 and can not be modified. So, it doesn't read bold enough like the usually heavy weight dashed lines used to indicate demolition. Using a Filled Region gives me the ability to affect the light weight but the Fill Region interferes with Keynote tags. The keynotes lose their host because the Filled region gets in the way.
I think it would be helpful if, in the PAT file where we create fill patterns, Revit could include another parameter for light weight and/or line style. Then, pattern creation may take on a two step process where first you defined the line style or reference an existing one, then indicate the rest of the pattern geometry using that line style. It might even be cool if you could mix line styles instead of having to define them each time within the pattern definition - i.e. Dashed weight 1, solid weight 3, dashed weight 1... (with the usually offset and origin beginnings).
...just trying to emphasize why having such a tool would be necessary.
Message 54 of 81
RobDraw
The IDEAS forum is a much better place for your thoughts. We are users like you here to ask or answer questions about how to use the program.
Good luck.
Rob
Message 55 of 81
JDA_Joe
Ketan,
Maybe you can help me control the appearance of hatch. I have a Wall with heavy line weight Sand hatch and Structural Framing with light line weight Sand hatch. See screenshot below. I would like them to be light, and even lighter than the Structural framing hatch. How can I manipulate this?
Message 56 of 81
JDA_Joe
I meant to send that to you. I inadvertently addressed it to Ketan.
Message 57 of 81
RobDraw
If you had read the thread or, at a minimum, the posts marked as solutions, you would have figured out that this is not possible.
Good luck!
Rob
Message 58 of 81
RDAOU
@RobDraw
(Assuming Hatch Pattern they are referring to Surface Patterns)
Overridden surface pattern will follow the Projection Line weight in object style....So technically it is possible if one applies the surface pattern as an Override (ex: using View Filter) ... + add to a view template should it be applicable to more than one view...
Downside would be that pattern overrides will be limited to Drafting Patterns ...
Message 59 of 81
JDA_Joe
I thought someone was suggesting a way to change the line weight of a hatch pattern, but I did not see that option. So there is no way to change the pattern of a projection surface or cut? If so, I'm disappointed. We're supposed to be in control, not the software. That is unfortunate because I have concrete framing over a concrete wall and I would simply like them to look the same. I want the projection surface to be very light, so I'm using Sand. The line weight of the wall makes it almost as dark as the cut pattern, which is makes the drawing hard to read.
The patterns are all mixed up:
See below. Cut floors have a lighter line weight than cut walls, but they should look the same; they are both cut concrete  Beam projection surface has a lighter line weight than wall projection, but they should look the same; they are both concrete projection surfaces.
Message 60 of 81
JDA_Joe
My solution for now is to forget about hatch patterns and go with grey solid fill. I think it reads well. See below
