Control Hatch Pattern Line Weights
Message 1 of 81
I found this being posted by number of people and a lot of answers marked as solutions. But they don't seem to work.
Hatch patterns seem to be understood as taking a default pen width 1. So While playing around for changing these hatch weights, I changed all pen 1 widths to 0.5mm, for all scales, in Manage > Settings > Additional Settings > Line Weights > Model Line Weights - Perspective Line Weights > Annotation Line Weights.
Nothing seems to change hatch pattern or cut surface pattern line weights. Could any sage help?
Accepted solutions (4)
Replies (80)
Message 21 of 81
As @ToanDN wrote, at least till Revit 2018, we cannot control material Hatch pattern line weights. Only Filled region Hatch pattern line weights can be controlled.
Message 22 of 81
I would like to clarify that I don't know how to manipulate the Material hatch pattern line weights, but maybe someone else can.  It's not a definite NO 😉
Message 23 of 81
So just to be clear we can seperately adjust the lineweight of hatch patterns and borders (ie one thin, the other thick) of filled regions but we can't seperately do this with individual elements of a wall family? Or has any progress been made on this?
If we can't then how are we supposed to transition to Revit (from AutoCAD) when the printed output just cannot match that of AutoCAD. This seems like a huge hole in Revit's armoury.
Message 24 of 81
RobDraw
If your product is only the printed output, then yeah, AutoCAD should probably be your choice of platform.
Most of us have had to make some concessions in our printed output, but that doesn't mean that we can't still have high quality prints.
Rob
Message 25 of 81
Thanks, understand your point, but I was hoping for a more specific answer to my question. Can anyone help?
Message 26 of 81
RobDraw
Well, it seems the topic of this thread has been solved and your issue is not really related. You will get better attention to your issue by starting a new topic.
Good luck!
Rob
Message 27 of 81
Sorry, but what are you talking about? I was asking if any progress had been made on the very subject the OP posted. My question still stands if anyone can help.
Message 28 of 81
Because the topic has been marked as Solved it doesn't get as much attention as a new one.
If you are talking about the individual patterns in an assembly wall then no, you cannot control the material fill pattern lineweight like you would with filled region.  Comparing it with AutoCAD is a bit unfair because in AutoCAD you do have to create the hatches manually.  You could do the same in Revit with drawing Fill regions manually to have the graphics of your liking but it defeats the strength of the program.
If you are talking about the lineweight of component lines within an assembly wall then there maybe ways around it.  Whether they are worth pursuing is up to each individual.  I find them such a waste of time but again I don't dictate others' graphics standards.
Message 29 of 81
The ability to change the color is available.  You could have 50 shades of grey.  lol  This might not be what you are looking for but overall can be used to produce noticeable variations.
Matthew
Message 30 of 81
Ok, thanks for the clear responses. Much appreciated.
Now hoping Autodesk bring in that feature at some point. Would be genuinely useful and help to lift graphics standards even further.
Message 31 of 81
fouad.ouahil
@kadmonkee wrote:
if you select the wall / edit type / Structure (edit button)
on the Materials column find the material you want to modify.
select the material button to bring you into the Material Browser
when you select the cut pattern it is reading the Drafting fill pattern - duplicate and rename this and change the properties to a hevier line weight and apply it here.
any modifications you do here will effect all of your Model using this particular Material.
maybe duplicate and customize for testing
Please can you delete your answer as there is no way to change hatch pattern PEN# for materials neither on drafting or model hatching.
I was confused about that and looked over and over again but you only can change the scale which can affect the line spacing,
Yes you can change the filled region hatch PEN# but there is no such option in materials cut or surface hatching.
Thank you in advanced.
Message 32 of 81
Haneenalbow
I don't have an option in the edit wall type dialog box called ( fill pattern line weights)
Message 33 of 81
geertfilippini1
All hatch patterns of 3d items are controlled by lineweight 1 under the tab Manage -> additional settings > lineweights -> lineweight 1. Here you can control the lineweight of hatch patterns for different scales.
Message 34 of 81
jsanders
Hello I have the same problem as OP, I want to change thickness of a cut pattern of a wall. From what I've seen it looks like it's impossible.
I really think that Revit should enable us to change the thickness of the lines inside a cut pattern.
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
Message 35 of 81
RobDraw
There is a forum for your IDEA.
Rob
Message 36 of 81
jsanders
You mean the Revit Forum, the one we are in know ?
Message 37 of 81
RobDraw
No, wise guy, the Revit IDEAS forum.
Rob
Message 38 of 81
jsanders
In that case maybe it would have been "wiser" to add the link in your initial post 😉
And also this thread pops up in top results when you type "change thickness pattern revit"
Message 39 of 81
RobDraw
Do you want me to do your homework, too?
Rob
Message 40 of 81
jsanders
Yes, if you can change the thickness of a cut pattern please do my work I would love to. Autodesk has decided to not make this feature possible and so we will never be able to control the thickness of our walls patterns.
I don't know if you're exactly a moderator of this forum but you should act like one 😉 I would advise you next time to simply send a private message instead of replying out of context, you are making the discussion sterile.
