Same Ceiling but shows differently when exported
3 ANTWORTEN 3
Nachricht 1 von 4
dianaTQH6W
319 Aufrufe, 3 Antworten
When I export the plan as PDF i see that the elements of a linked revit model are partly hidden behind a ceiling (e.g. orange revision openings are not filled), whereas on another ceiling of the exact same type, paramters and height, it doesnt. I have already checked the linked revit file, the elements of those are modelled correctly.
Could it have something to do with export settings? It doesnt show in the model view, only when exported (see attached file).
Ill be very thankful about any tips or clues!
thanks in advnace and best greetings
Diana
3 ANTWORTEN 3
Nachricht 2 von 4
Simon_Weel
als Antwort auf: dianaTQH6W
Exported to what? The picture doesn't help much as I don't know how it should look?
Nachricht 3 von 4
dianaTQH6W
als Antwort auf: Simon_Weel
thanks Simon, you are right. Ive edited the inital post to make it more clear.
Nachricht 4 von 4
syman2000
Is that screenshot from PDF export or from Revit?
